Activity Forums VEGAS Pro Scope check box 7.5IRE
  • Scope check box 7.5IRE
    Posted by Mark Krueger on September 12, 2011 at 7:56 pm
    When using the video scopes to help with contrast and brightness and color correction there is a setting whereby you can select a 7.5 setup. My question is should this be checked with HD media?
    John Rofrano replied 15 years ago 2 Members · 1 Reply
  • John Rofrano
    September 12, 2011 at 8:44 pm
    [Mark Krueger] “When using the video scopes to help with contrast and brightness and color correction there is a setting whereby you can select a 7.5 setup. My question is should this be checked with HD media?”
    No. This has nothing to do with SD or HD and has absolutely no affect on the video. This is just a configuration setting that affects the display of the scopes to make it consistent with an external scope connected to a device that adds 7.5 IRE setup. If you don’t have an external hardware scope, there is no reason to ever check this box.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
