Activity Forums Apple Final Cut Pro Legacy Scene Detection?
  • Scene Detection?
    Posted by Lokidrummer on November 17, 2005 at 2:16 am
    Hi, i recently got final cut pro 4.5 hd and want to know if it can do automatic scene detection. Kinda like in vegas. I know that final cut will split the video at timecode breaks but how can i make it split the files into actual scenes. Thanks
    -William
    David Wishnie replied 18 years, 6 months ago 5 Members · 7 Replies
  • 7 Replies
  • Lokidrummer
    November 17, 2005 at 2:49 am
    I tried the dv start/stop thing and it told me that it had no breaks but i there are breaks. I’ll try to explain it better.
    I filmed a skater right, so i hit record he bails, it record again he repositions, then i start recording again and he nails it. What final cut did was put all this as one clip, when i would want those seperate. I know the Sony Vegas did this unless you told it not to, but how can i get final cut hd to do this
  • Jeremy Garchow
    November 17, 2005 at 3:28 am
    Start stop does not work on the breaks of your tape, it works with the metadata of the internal clock of your dv camcorder. If you have a clock on your camcorder, set it, and make sure it works. Otherwise, FCP will not automatically detect when you hit the record button to start or stop.
  • Lokidrummer
    November 17, 2005 at 4:04 am
    Hm….that really really sucks, cause it could have saved alot of time. Any other way? I have like a full tape of it. Thanks
    Also, i might know why, i had the raw footage on a computer, and took it off and put it on this one….but i’m suprised final cut can’t do just a scene detection just by recognizing a cut rather than looking at the timecode….but yea any other possible way?
    -Will
  • Jeremy Garchow
    November 17, 2005 at 4:43 am
    With what system did you digitize the footage originally?
  • Trevor Asquerthian
    November 17, 2005 at 10:51 am
    catdv http://www.catdv.com will analyse a file and give a log depending on scene changes… they have a demo available i believe…. should do what you are looking for
  • Gary Brown
    November 18, 2005 at 8:06 pm
    HD Log is also available. It can scene detect directly off of a tape or from a QuickTime file.
    https://imagineproducts.com/hdlog.htm
  • David Wishnie
    March 10, 2008 at 6:05 pm
    Hello,
    This tool can do this too:
    https://www.scene-detector.com
