Activity › Forums › Adobe Premiere Pro › Scene Detection workflow suggestions?
Posted by Eric Mueller on February 23, 2015 at 6:24 pmI need to recycle b-roll from a bunch of finished programs (some h.264 masters, but mostly Prores masters) for a new project.
Is there an effective workflow for doing this in CC via a plug-in or Speedgrade’s scene detection? Ideally I’d like to identify and move subclips from each existing master into its own bin in PP to use as source material in the new project. I also have Resolve Lite – is there an option via XML that would get those results?
Tim Wilson replied 6 years, 2 months ago 6 Members · 8 Replies -
Trevor Asquerthian
February 23, 2015 at 10:46 pmI’ve done this successfully with Resolve as the Scene Detector and Avid as the destination via AAF.
I take only the ‘Cut’ info (i.e. Edit Decisions) via AAF, not the media, and use an effect in Avid that will subdivide one Video clip based on a different layer to notch the flattened master.
I’ve tried this with Resolve to Premiere – and found that I could only rely on the ‘Cut’ info with this route and had to manually slice up in a similar way to notching in Avid (in fact using a macro to do the manual work)
Here’s the potted workflow & where the problems were:
In Resolve:
Create new project (or new folder in Media Pool so your clips don’t get confused with any others)
Find clip in Media Tab | Library
Right Click and select ‘Scene Cut Detection’
Click ‘Start’
Save SceneCut (in case of crashes) via the top right 3 dot menu
Refine the edits as necessary (use – to remove them, or adjust the purple ‘threshold’ for where it detects cuts)
Save SceneCut again (just in case – it’ll save you doing that work again)
‘Add Clips to Media Pool’
Switch to Edit Tab
Select All Clips in Media Pool (or folder)
Right click and ‘create sequence with selected clips’ (they should be sorted correctly and now be a timeline of your full clip, but notched)
Right click resulting sequence and export as:AAF – doesn’t work well into Pr – cuts in right place but sequence clip always starts at beginning of source clip. Also audio is ‘nested’ for some reason.
XML – again cuts in right place but source clip always at start
EDL – not linked, no audio, no cuts as presumably optimised – not much use
FCP1.3 or 1.4 XML – will not import
SOLUTION:
Export from Resolve as AAF
Import that AAF to Pr and delete audio tracks
Import full clip to Pr and ‘create sequence from clip’
Put AAF timeline on V2 of this sequence
With V1 & V2 selected:
step to next edit
add-edit
repeatI’ve not used this in anger in Pr though. Oh and the Speedgrade scene detection was a lot slower
Trevor Asquerthian
February 23, 2015 at 11:15 pmCatDV also has scene detection – and is much more able to log and provide subclips to various NLEs
Eric Mueller
February 24, 2015 at 1:14 amThanks for the detailed info, Trevor. I figured an XML route would be better for Premiere/Resolve, but I may just move this to MC based on what you’re saying. As an added benefit, I’ll have something billable to show for the $295 I sent to Avid on December 31st…
Thanks again!
Ju Dor
November 24, 2015 at 8:44 pmHi Trevor
What do you mean with this? and have these issues been resolved (no pun intended) with the latest versions of Resolve 12 and Premiere CC 2015.2sequence clip always starts at beginning of source clip.
I like the idea of scene detection. Could save a lot of time.
Also, has anyone had any luck with this script for premiere?
https://aescripts.com/magnum/ -
Jeremy Solterbeck
December 19, 2018 at 6:20 pmI have had the same problem for years, and can barely find anyone round tripping to DaVinci. Really does no one need this? The fact that Premiere can’t read an XML correctly and hasn’t for years seems absurd. Clearly it sees the cuts, so my assumption is it just doesn’t like the format o the timecode coming out of DaVinci. Someone smart could surely make a script that would fix the timecode layout, the way all those subtitling utilities fixes Premiere’s own timecode for Encore.
Trevor Asquerthian
December 20, 2018 at 9:33 amI haven’t tried it in PP for a while but there is a vote open – https://adobe-video.uservoice.com/forums/911233-premiere-pro/suggestions/33924388-auto-scene-cut-detection
Brecht Debackere
May 23, 2020 at 8:54 pmWhile many of you have probably moved on or resolved this issue in different ways, I just want to throw this out there:
I made a script which converts an XML FCP7 file from resolve to a working PremierePro .xml. I’ve tested it on a number of files, and so far it does what I needed it to do. If anyone needs it, you can grab it here (instructions included) : https://gumroad.com/products/CUnOP
Tim Wilson
June 26, 2020 at 4:49 amI happened across this thread, and noted that the June 2020 update of the Creative Cloud applications includes a public beta of Scene Edit Detection in Premiere Pro. Adobe’s Eric Philpott told us about it in an article here: https://library.creativecow.net/philpott_eric/adobe-stock-audio-roto-brush-2-creative-cloud-updates/1
Here’s what he wrote about it:
Scene Edit Detection in Premiere Pro will leverage Adobe Sensei to analyze exported or archived video files and identify edits with pinpoint accuracy. Unlike existing histogram-based solutions, the new technology in Premiere Pro was built with machine learning, helping users to save time by delivering consistently reliable results. Scene Edit Detection will automatically add cuts or markers at each edit point, turning rendered files into editable timelines and enabling per-clip adjustments, such as color correction or reframing.
Learn more about installing the public beta software here.
