Activity › Forums › Adobe Premiere Pro › Scene Detection on Imported AVI Files with Premiere Pro CS5.5
  • Scene Detection on Imported AVI Files with Premiere Pro CS5.5
    Posted by John Millns on May 31, 2011 at 11:15 am
    I am currently evaluating the 5.5 trial version and I cannot see a way to carry out ‘optical’ or ‘content’ scene detection on imported avi, or similar files that would not have embedded time/date info. I am frequently sent files for editing that were previously captured analogue video from VHS, Hi8, etc, so this feature is rather important.
    Does anyone know if this is a limitation of the trial version, or is this something that consumer editors can do, that cannot be easily done with cs5.5?
    John Millns replied 14 years, 6 months ago 3 Members · 8 Replies
  • 8 Replies
  • Todd Kopriva
    May 31, 2011 at 2:19 pm
    There are no limitations to the trial version.
    Scene detection works only during capture.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Ann Bens
    May 31, 2011 at 6:48 pm
    Premiere has never been able to do this.
    Scenalyzer has optical scene detection.
    There is the free version and a buy version.
    https://www.scenalyzer.com/main.html
  • John Millns
    June 1, 2011 at 8:53 pm
    Thanks for the info. I confess that I am a little disappointed that Premiere still doesn’t have a facility to optically detect scenes while capturing, or on imported files, particularly as this available on most consumer editors, including the Windows version. A pity, as there is still a great deal of analogue video that needs to be digitised, edited and transferred to to DVD before the tapes deteriorate too far.
    I tried Scenalyzer and found it rather over does it, detecting even minor changes as new scenes, even on the least sensitive setting and again, it cannot import avi files and detect scenes.
  • Todd Kopriva
    June 1, 2011 at 9:26 pm
    If you’re willing to go to After Effects to do it, then you could use Magnum:
    https://aescripts.com/magnum-the-edit-detector/
  • John Millns
    June 2, 2011 at 8:51 am
    Thanks for that suggestion, which I have just finished studying. Unfortunately, I get the impression that this would not be as quick and easy to use as the scene detection systems in consumer editors, which will also deal with imported files.
    I was hoping to get away from the need to run two editing systems and upgrade to Premiere Pro CS5.5 for everything and use the Matrox MX02 mini for the interface. I thought the MX02 mini would definitely have optical/content scene detection, as it is designed to include analogue capture. But I cannot find any reference to it in the user manual.
    It seems ironic that my old semi-pro Pinnacle DV500/Prem Pro 6 set up, that I still use for analogue capture, had these scene detection facilities in 2002, which are still not standard features on pro editors now.
  • John Millns
    December 20, 2011 at 11:54 am
    I have finally found some software called ‘AV Cutty’, that will do this as well as the Pinnacle Studio 15 import/capture facility. In fact it is potentially better, as there is far more control over the scene splitting settings.
    The key point is that it is lossless and allows you to produce a separate AVI file for each scene, without messing up the quality.
    I ran it on a 20min avi (at the default settings) and then compared it with the Studio 15 scene detection: AVCutty produced 41 scenes, very close to the 39 from Studio 15.
    It can also be used while capturing, but I haven’t tried this as yet.
    There was no problem importing and using these files with Prem Pro CS5.5. So at long last, I can use CS5.5 to edit long AVI files without spending a very long time splitting scenes manually.
    See: https://www.freevideoworkshop.com/freewareavcutty.htm
  • Ann Bens
    March 8, 2012 at 5:49 pm
    Pinnacle Studio does not split your avi into scene, its all optical.
    In Studio you are still editing one long file.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • John Millns
    March 8, 2012 at 10:57 pm
    Thank you. I was aware that Pinnacle Studio didn’t actually ‘split’ the scenes, it just produces marker tabs for Studio to simulate the effect. Otherwise, it may have been possible to import any resultant split output files into Premiere. In contrast AvCutty does split the AVI file into scenes (losslessly), so they can be imported directly into Premiere.
