Activity Forums DVD Authoring Scenarist – using .scp files for reauthoring
  • Scenarist – using .scp files for reauthoring
    Posted by David Smith on August 27, 2010 at 1:24 am
    Is it possible to “automatically” reauthor a project in Scenarist with a demuxed DVD that has a scp file with it? The manual is disgustingly vague on how that works.
    Eric Pautsch replied 16 years ago 3 Members · 3 Replies
  • Eric Pautsch
    August 27, 2010 at 2:52 am
    The manual doesn’t go over stuff like that. Technically you could but it would take so long it wouldn’t be worth the effort. For this you would need a copy of ReAuthor to make a new Scenario and add your new streams
    https://www.dvd-logic.com/reauthor2.htm
  • Roman Melekh
    August 27, 2010 at 10:23 am
    “DVD that has a scp” is ONLY DVDReauthor’s work.
    If you have already re-authored disk (video, audio, subs and scp file) you can import .scp to Scenarist and use project like your project.
  • Eric Pautsch
    August 27, 2010 at 11:52 am
    You could do it without reAuthor but I would never want to.
