Activity › Forums › DVD Authoring › Scenarist skips title menu from open
  • Scenarist skips title menu from open
    Posted by Edit 108 on March 19, 2007 at 8:20 pm
    My first play on the DVD is an open video (which i have in the VideoManager folder with my main menu). The post command on the open video is for the Main (Title) Menu, but if you press skip on the remote while the open is playing, it takes you to the root menu in VTS_1.
    The client really wants to see the main menu after the open when he hits skip on the remote & i’m sad to say, i don’t know how to redirect the action to go to the title menu instead of the root! (Even though if left to play in it’s entirety, it goes to the Title menu anyway).
    Any ideas???
    Edit 108 replied 19 years, 5 months ago 3 Members · 4 Replies
  • Eric Pautsch
    March 19, 2007 at 10:55 pm
    Mmmmm…not sure why it’s going to the root menu of VTS 1. Pretty simple fix here. Instead of going to a menu in the VGM, go to a Title first (TT which is good practice anyway to prime your player buffer).
    In the track editor put a chapter (PG) 1 sec before the end of the track. Then disable your UOPS for “Next” & “Previous” for that final PG (chapter). Here’s how it will work:
    First Play – VTS 1(TT1) – post command main menu. When your client hits next during the “Open” they will skip to that chapter you put in there, then immediately (1 sec) post command up to the VGM where your Main Menu sits.
  • George Wing
    March 20, 2007 at 11:53 am
    Hi Eric,
    Which software will allow me to modify the UOPS on a specific CHAPTER? I didn’t know that was possible, but will be cool to implement it 🙂
    Regards,
    George
  • Eric Pautsch
    March 25, 2007 at 1:29 pm
    Scenarist will. Not sure about DVDSP or others.
  • Edit 108
    April 9, 2007 at 3:41 pm
    Thanks Eric, I know i’m a bit late in response, but i appreciate the help.
