Activity › Forums › DVD Authoring › Scenarist DVD Authoring
Posted by Edit 108 on February 9, 2006 at 2:18 pmHas anyone had experience using Scenarist, the button functionality seems extremely limited. Any creative ideas?
Katalex replied 20 years, 5 months ago 6 Members · 10 Replies -
Chris Borjis
February 9, 2006 at 5:54 pmTo be honest, there is absolutely nothing that is “limiting” about Scenarist.
It IS the gold standard for DVD authoring.
I do know that the documentation is not very good though.
You should contact Sonic Support if you need assistance.
Edit 108
February 10, 2006 at 2:29 pmI’m trying to make the buttons (on selection) change color & get larger in size. Any ideas? This is my first project working with Scenarist & i have no idea just how creative you can get with buttons.
Edit 108
February 10, 2006 at 2:36 pmI’m trying to make the buttons (on selection) change color & get larger. Any ideas? This is my first project using Scenarist & i’m not sure just how creative you can be with subpicture layers.
Edit 108
February 10, 2006 at 2:42 pmI’m trying to make the buttons change color & get bigger on selection (& change color again for action).
Any ideas? This is my first project working with Scenarist & i’m unsure of the subpicture capabilities. -
Dave Friend
February 11, 2006 at 8:39 pmI am not sure I understand what you mean my “get larger in size.” Please elaborate.
I suspect what you are looking for might require multiple background images. It can done, but
could get tedious depending on the quantity of buttons. A better understanding of what you want to achieve will make it easier to help.Dave
Eric Pautsch
February 13, 2006 at 4:53 pmJust like most authoring apps you can use different colors or greyscales to effect your active, selection or normal states. The work you need to do is in photoshop or illstrator.
BTW…Sonic doesn’t have the best support in the world but Im sure someone can help you out there since youve spent tens of thousands of dollars for this authoring platform…right?
Edit 108
February 13, 2006 at 10:15 pmI have a main menu with 6 word options on to navigate to specific programs.
I would like to add an effect when you select the word that makes the word appear like its bigger because you selected it (like on the internet). I’m not sure if this is overambitious or if it can be done.
Does this make sense?
I’m confused because the menu is a moving menu with audio so if i point to another menu it will not sync. Can i have multiple subpictures so i can go to another subpicture on selection.
I’m probably looking at this completely the wrong way! -
Rob Neidig
February 13, 2006 at 11:24 pmAs others have suggested, what you are trying to do is not a limitation of Scenarist, but of the DVD specification. If you want the buttons to change when selected, then you will have to create a new menu background to jump to at that point. That would result in a visible jump and change in audio as well. Again, this is not a limitation of Scenarist – it has access to the full capability of DVD – it is that DVDs were never designed to be able to do that.
Hope this helps.
Have fun!
Rob
Katalex
March 22, 2006 at 9:10 pmAs Rob says, it`s a limitation in the DVD specs, not in Scenarist. We use scenarist since 14 months on a daily basis. Our recommendation: put your creativity in the menu layout and in creating cool motion menus and transitions, but NOT in motion of button overlays, etc. this will also help you improve the overall compatibility of your final disc. Look at some Hollywood-made DVD`s. The simplicity of the overlays, and selection/active state is sometimes overdone, but I guess they also know why.
grz
JanKatalex
