Activity Forums Adobe After Effects scatter graph animation
  • scatter graph animation
    Posted by Karen Mansy on August 6, 2023 at 3:26 pm
    Hi, newbie here-trying to create a small animation for a website of a scattergraph-basically animating random dots to move towards an axis. should this be animated manually or is there a preset that could do this quickly? thanks for your help? (image attached)
    Filip Vandueren replied 3 years, 1 month ago 2 Members · 3 Replies
  • Filip Vandueren
    August 7, 2023 at 12:15 pm
    Hi Karen,
    if you just want something random and don’t need to control the actual values, I would do this with a text-animator:
    Make a text layer containing •••••••••••••••••••••••••…
    Draw your trend line as a mask-line on this text layer, then enable text on Path.
    Add a position animator with Wiggly textanimator (but with Wiggles per sec at 0 so it’s fixed).
    Give the animator’s Position-value a bit of X and some more Y depending on how scattered you want it to be.
    You can add another text animator to anim-on the dots 1 by 1 (with opacity, perhaps scale), and a third animator could be used to add random colors to the dots.
  • Karen Mansy
    August 8, 2023 at 4:22 am
    thanks heaps! would you be able to point me to a tutorial or website that goes through these steps? not sure if I know where the ‘wiggle text animator’ is
  • Filip Vandueren
    August 8, 2023 at 6:17 am
    Here’s a pretty in depth tutorial on text animators, the wiggly selector is first shown around the 10:30 mark:
    https://youtu.be/plbsdkRhy8g
