Activity › Forums › Adobe Illustrator › Scatter brush
Scatter brush
Posted by Korben Dallas on October 29, 2015 at 1:25 amHi!
Does anyone know if it is possible to create a scatter brush with more than one shape?
Thank you!
Korben Dallas replied 10 years, 11 months ago 2 Members · 4 Replies -
Vincent Rosati
October 29, 2015 at 4:54 pmKorben my man, you can duplicate the path in the Appearance palette and select a different brush.
We green?Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Korben Dallas
October 29, 2015 at 5:54 pmHi Vince thanks for your reply, what i want to do is use letters to create something like this:
https://previews.123rf.com/images/jordygraph/jordygraph0905/jordygraph090500001/4807198-Many-letters-and-numbers-compose-the-brain-Stock-Photo.jpg
Maybe there is a script or something else.Thank you!
Vincent Rosati
October 29, 2015 at 7:04 pmI don’t know of any scripts that would do this. There could be, but not that I’m aware of.
I’d bet this was done by hand. The artist had a structure, in this case an illustration of a brain. Then off to the side, they created a type object or expanded type of each letter, then copy/dragged each letter into place.
I’d estimate this would take 2-3 hours, but potentially as little as an hour.
If this request came across my desk I’d do it by hand.I’m not sure how a script might achieve this. I’m sure it could. Maybe each letter is a symbol, and you make a script that somehow fills an object with random letters, set to random rotation and random size within a defined range, with no overlapping.
Or maybe populate the letters based on a greyscale raster.. Not sure if that’s even possible.That leads to why I think this was done by hand – the letters around the edges are flush with the edge.
Regarding the color, that can just be a single gradient applied to the art, after the structure is finished and you make everything a single compound path.
Maybe someone else will chime in with another idea.
Vince
Korben Dallas
October 30, 2015 at 8:13 pmI think it was done by hand too, but i was hoping there was an easier way to do it
Thank you for the tips!
