Activity Forums Avid Media Composer Scanning documents for AVID
  • Scanning documents for AVID
    Posted by Genevieve Baker on August 28, 2008 at 9:27 pm
    I am trying to do extreme close up zooms on scanned documents (eg newspaper articles that start with the entire front page zooming into one word) and it’s not working. I lose all clarity when I zoom in too close. I scanned the documents at very high settings (1200dpi) and then edited in photoshop to fit within a 16×9 anamorphic screen. Anyone have any suggestions?
    Grinner Hester replied 18 years ago 3 Members · 2 Replies
  • Michael Hancock
    August 28, 2008 at 9:34 pm
    In video, DPI means absolutely nothing.
    You need to use the Pan and Zoom effect in Avid, or look into using After Effects, Boris Red, or StageTools (an Avid Plugin) for this.
    Avid’s Pan and Zoom will do what you want, but won’t rotate. You can do these things easily in Boris or AE if you’re familiar with them, and it will probably take about 3 minutes to learn StageTools if you decide to go that route (a great plugin, but not incredibly cheap).
    If you use Avid’s Pan and Zoom, you’ll be limited to 3000 x 3000 pixels if I remember right. So can your photo in to be 3000 x 3000 pixels (or bigger, then crop the bit you need). Leave it this size, and save it as a targa.
    Import that picture into Avid and it will resize it. Drop it into your timeline where you want to do the move, then apply the Pan and Zoom effect. Open the effect editor and click the gray button by Pan and Zoom. It will open a box where you navigate to the 3000 x 3000 picture on your hard drive. Keyframe your movement, set it to highest quality, and render (read the help files for more on how the effect works).
    Voila! Zoom into pictures without quality loss.
    Michael.
  • Grinner Hester
    September 1, 2008 at 9:02 pm
    Use after effects for this.
