Activity › Forums › Adobe Premiere Pro › Scan Lines when clip running only
Posted by Dorian Weber on April 20, 2019 at 2:32 amHello,
you guys have always been very helpful when I encountered problems.
Here is something I like to know:
For special effect clips, I get a perfect clip, on a single frame (when it stops) but when it runs, I get a lot of…. I would call them- scan lines.
Is there any way to remove those?Many thanks in advance.
Dorian
Dorian Weber replied 7 years, 5 months ago 3 Members · 5 Replies -
Jon Doughtie
April 20, 2019 at 9:59 amIf your footage is interlaced, the first thing I would check is sequence settings. NTSC analog SD should be lower field first for the interlace, and ATSC 1080i HD should be upper field first.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2017.1 (as of 8/2017)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF. -
Dorian Weber
April 22, 2019 at 8:48 amthank you Jon, I tried both, but still the same.
Actually the footage is progressive. With some transcoding I get a very interesting effect. It looks good on a single frame, but when I run it it has lots of horizontal lines accross.
Is there any way to remove those with one of the zig filters in Premier or After Effects?Thanks
Dorian
Jon Doughtie
April 22, 2019 at 5:05 pmHmm. What is your original footage (container and codec)? And what are you transcoding to (container and codec)?
System:
Win 7 64-bit
32GB RAM
Todd Perchert
April 22, 2019 at 6:38 pmCan you post an image of this? Seeing it would go a long way in helping you. Could be a few different things.
TC -
Dorian Weber
April 24, 2019 at 1:00 pmI think, I found the problem: because I exported it into Premier. This seem to have added the scanlines. Now I drag it direct into Media encoder, and it comes out very well.
I only found out when I wanted to upload a new encoded clip to show you.Problem solved.
Thanks guys for your offer to help me.
Dorian
