Activity › Forums › Adobe After Effects Expressions › scaling with expressions
Posted by Clemensk on May 9, 2006 at 4:53 pmI have tons of layers which have to be scaled from 0 to 100 over a length of 10 frames, starting at the inpoint of the layers and scaled from 100 to 0 at the end.
Doing this with expressions could save me a lot of time but i can’t figure out how to do this.Anybody can help?
best regards
ClemensDan Ebbertsreplied 20 years, 4 months ago 2 Members · 4 Replies
Clemensk
May 9, 2006 at 5:52 pmi found a simple solution myself but maybe you can help me to improve the script. the layer is scaled now linear from 0 to 63 beginning at the inpoint. It would surely look better if it goes from for example from 0 to 80 in 10 frames and from 80 to 63 in 3 frames.
any ideas.
best regards
Clemensadjust = 90
temp= time – inPoint;
temp = temp * adjust
temp =Math.min(temp, 63) ;outtemp= outPoint -time;
outtemp = outtemp * adjust
outtemp =Math.min(outtemp, 63) ;
temp =Math.min(temp, outtemp) ;[temp,temp]
Dan Ebberts
May 9, 2006 at 6:46 pmI’m not sure what your expression does, but I think this one does what you originally asked for:
f = 10; // number of frames to ramp
t = f*thisComp.frameDuration;
s = Math.min(linear(time,inPoint,inPoint+t,0,100),linear(time,outPoint-t,outPoint,100,0));
[s,s]Dan
Clemensk
May 9, 2006 at 7:07 pmthank you for your reply.
nice script, looks much better than the one i figured out, but basically they do the same. Do you have a solution for my second question too? some sort of easing which slightly overshoots the target value.
for example 0 > 120 > 100???
Clemens
Dan Ebberts
May 9, 2006 at 8:36 pmOK – try this:
f1 = 10; // ramp on/off frames
f2 = 3; // overshoot framesmax = 80; //maximum scale value
hold = 63; // hold scale valuet1 = f1*thisComp.frameDuration;
t2 = f2*thisComp.frameDuration;if (time <= inPoint + t1 + t2){ s = Math.min(linear(time,inPoint,inPoint+t1,0,max),linear(time,inPoint+t1,inPoint+t1+t2,max,hold)); }else{ s = linear(time,outPoint-t1,outPoint,hold,0); } [s,s] Dan
