Activity Forums Adobe After Effects Scaling up a composition (with Element 3D)
  • Scaling up a composition (with Element 3D)
    Posted by Claire Wilkins on January 11, 2017 at 11:13 am
    Hey all,
    I made a rookie error. I’ve edited a video in 960 x 720 (4:3- this part was intentional) but suddenly the clients changed their mind and wants to put it on 2 screens – still 4:3 but higher definition.
    I understand i should use 1440 x 1080 to get a high resolution output that is still within 4:3, and i’ve read that i can use:
    Scripts > Scale selected layers/ Scale composition – to get the composition to scale up to this size . A. Is this correct or will i still be pixelating everything?
    Secondly, the above does not seem to affect the Element 3D text/Logo I’ve placed in the animation- is there a way to scale this up also so that i don’t have to painstakingly reanimate the camera movement?
    -Claire
    Junior Content Manager – MCI UK
    Claire Wilkins replied 9 years, 7 months ago 3 Members · 5 Replies
  • Claire Wilkins
    January 11, 2017 at 1:06 pm
    Desperate for anyones help on this :,( – If anyone has any bright ideas – or i am going to have to start from scratch with no time to get it done.
    eep!
  • Walter Soyka
    January 11, 2017 at 1:30 pm
    Run the script, then change the size of the solid to which Element is applied to match the new comp size and reset its scale.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Daniel Waldron
    January 11, 2017 at 1:42 pm
    You could try this free script. I’m just not sure if scaling up the Element 3D solid will change the size of your model, but it’s worth a shot.
  • Claire Wilkins
    January 11, 2017 at 2:35 pm
    Hi Walter,
    Thank you so much for your advice, but ( and it’s probably me panicking a little) I can’t get it to work.
    Could you perhaps take a look at the Project file for me if i upload it with any assets??
    I’m at my witts end with it all!
    -Claire
  • Claire Wilkins
    January 11, 2017 at 2:41 pm
    10946_visioncarebackdrop43v2a.aep.zip
    Here is my .AEP file
