Activity Forums Apple Final Cut Pro Legacy Scaling Stills and Jagged Movements
  • Scaling Stills and Jagged Movements
    Posted by Alan Callaghan on November 19, 2008 at 6:30 am
    Hello,
    So I am cutting a piece with some stills, and some created freeze frames in my FCP project. I am adding a simple “zoom” by increasing the image’s size and adding keyframes (like 100 to 120, with keyframes in the motion tap). All of this is in FCP.
    Now, when I add a transition (cross dissolve) to the the clip I notice when I playback from the timeline it’s kinda jagged while it does the dissolve. Is this just what it does in FCP? Will it be smooth over the transitions when I lay this off to tape? IS there something I should make sure is off, like frame blending?
    thanks for your time!
    alan
    David Roth weiss replied 17 years, 10 months ago 2 Members · 1 Reply
  • David Roth weiss
    November 19, 2008 at 7:01 am
    You need to render the dissolves, and you have to make certain that all of the render options are checked, including “Full” in the render dropdown menu before you render.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
