Activity Forums Adobe After Effects scaling shortcut
  • scaling shortcut
    Posted by Steven J casey on August 17, 2005 at 4:40 pm
    Brand new, using 6.5, working on first disc of Total Training. There’s a reference to using alt-click and drag to scale a layer. This doesn’t work on my machine, it only switches to a wireframe and moves the layer. Am I missing something here?
    thanks
    steve
    Steven J casey replied 21 years ago 3 Members · 3 Replies
  • Aharon Rabinowitz
    August 18, 2005 at 3:39 am
    You have to grab it by the corner ponts to scale.
    If the Live update button (2 square, one white with an x over a grey one)is on in the timeline Alt will make it work in wireframe for the transformation. Otherwise the opposite -it transforms in wireframe always, unless you hit Alt.
    Shift while dragging the corner scales it equally on all sides.
    Alt+Shift will do a combo of the 2.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • John Dickinson
    August 18, 2005 at 8:43 pm
    I remember that you could scale a layer this way in previous versions. It was handy when you were zoomed in and couldn’t see the control points. There is a keyboard shortcut for scaling which you may find hand, it’s Option (alt on PC) and the plus/minus keys on the keypad. Hold down Shift as well to scale by a factor of 10.
    JD
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Steven J casey
    August 18, 2005 at 11:16 pm
    Yeah, the key to this tip was that if the handles are off screen you could shrink the image without panning around. The plus/minus keys seem to be a good tip though. Thanks for the responses!
