Activity Forums Adobe After Effects Expressions scaling on a slider
  • scaling on a slider
    Posted by Sean Kimber on December 16, 2009 at 9:00 pm
    I apologize if this has already been covered, but I haven’t been able to find any information while scouring the archives. I’m just starting in the (scary) world of expressions, so I know this is a simple question but I can’t figure it out. I’m trying to attach a wiggle to the scale property of a layer, but have the wiggle’s amplitude affected by a slider. I’ve tried many different ideas, but nothing seems to be working. (I did just have success doing the same idea with the y value of a position property. Here’s my latest expression attempt. What am I doing wrong?
    x=value[0]+wiggle(thisComp.layer("Null 1").effect("Slider Control")("Slider"),10);
    y=value[1]+wiggle(thisComp.layer("Null 1").effect("Slider Control")("Slider"),10);
    [x,y]
    Sean Kimber replied 16 years, 9 months ago 2 Members · 2 Replies
  • Xinlai Ni
    December 16, 2009 at 10:21 pm
    try this instead:
    value + wiggle(val1, val2)
    because wiggle returns a vector of the same dimension as the property it applies to.
    Xinlai Ni
    Software Engineer, Google Inc.
  • Sean Kimber
    December 17, 2009 at 2:05 pm
    Thanks for the suggestion. I ended up figuring it out before reading this. I copied and pasted the expression below. It worked exactly as I wanted. Thanks for the help!
    x= wiggle(thisComp.layer("Null 1").effect("Slider Control")("Slider"),10);
    [x[0],x[0]]
