Activity Forums Adobe After Effects Scaling Masks from 720X480 to 1280X720
  • Scaling Masks from 720X480 to 1280X720
    Posted by Eric Goldstein on November 22, 2006 at 8:51 pm
    I’m scaling a project up from 720X480 to 1280X720. Footage is being scaled up seperately. I have existing masks that are keyframed. Is there a way to make a global change to the different key frames to scale everything at once?
    Thanks for your help. Happy Thanksgiving.
    Eric
    Eric Goldstein
    Giraffe Film Company
    Los Angeles
    eric@giraffefilm.com
    Ht Davis replied 11 years, 4 months ago 3 Members · 6 Replies
  • Eric Goldstein
    November 22, 2006 at 9:48 pm
    Hi it turns out that AE scales the mask according to the new layer size. So, I don’t need to scale it. However,
    the mask isn’t positioned correctly. So, is there a way to globally change the position of the mask for all key frames?
    Eric
    Eric Goldstein
    Los Angeles
  • Straight A
    November 22, 2006 at 11:02 pm
    Put your timeline bar over one of the masks key frames, highlight all the keyframes you want moving together then move your mask.
    All the mask positions with keyframes highlighted will be moved together.
  • Eric Goldstein
    November 22, 2006 at 11:39 pm
    I tried what you suggested, but only the keyframe unter the CTI changed. I’m working in AE 6.5. Does this work in 6.5?
    Eric
    Eric Goldstein
    Los Angeles
  • Straight A
    November 23, 2006 at 12:48 am
    Hmmmm…
    Just tried it and you are right it doesn’t work !!
    I know that selecting all the key frames for other values (like position) and moving one – moves them all, but it doesn’t seem to work for masks 🙁
    Can you not just move the layer position to where you want it ?
    Or copy the mask onto a new white solid, put it on a black background pre-comp them both and use this a matte.
  • Eric Goldstein
    November 25, 2006 at 5:00 am
    Hi Dave,
    I’m working with 720X480 .9 pixel size. Actually the mattes are coming up slightly off horizontally and vertically. But once I line them up, they fit without any other adjustments.
    Eric
    Eric Goldstein
    Los Angeles
  • Ht Davis
    April 28, 2015 at 6:15 pm
    It sounds to me like you are doing something with the position because they all come out a little off. This is like placing a transparency or paste into photoshop. You have to do it one at a time on the keyframes. However, there are instances where you could move all the positioning. Scripting for instance. I’m not much for scripting myself (truth be told I’ve done it once and that was following a how to).
    I can offer you only my algorithm for what you want, not the code or script, because I stink at that part.
    Assumptions:
    the keyframes are all within the same entity\layer separate from other effects
    the keyframes all need to move both horizontally and vertically by the same amount each path but not necessarily by the same amount in both directions
    This movement can be scripted by using the position values associated with the position modifiers of the keyframes, and the keyframes themselves can be scripted into an array for use (that second part is less necessary)
    There are a number of possibilities here.
    First, if you can script the keyframes themselves into an array or a For loop\post test loop, you can process each one in the script.
    Algorithm:
    set defaults to zero
    Wait for input{
    Get horizontal move
    get vertical move
    endbutton
    change button}
    if changebutton{
    do[
    add to horizontal position
    add to vertical position]
    While there are more keyframes
    return to wait for input}
    else endscript
    if you can’t figure out how to script the test or array the keyframes, you’ll need to apply it to every keyframe separately. But that doesn’t mean you can’t adjust one of them until it’s right, then apply it to every other keyframe.
    IF you set the movement in the script and apply that script to 1 keyframe, keeping track of your adding\subtracting, you can get the values to apply to all the others, or you can note the current values of one keyframe, move it into place, and then use that to get the values to apply to the others. After that, you simply put those into the script, set the script to a hotkey, and click each key frame, pressing the hotkey as you go, which will apply the movement.
    Algorithm:
    Set x
    Set y
    with current keyframe{
    move x horizontal
    move y vertical
    For a script to set the x\y you could have it ask the user for the value, and store it in an environment variable. This would be a defaults container you could reset with another script. Once set, the algorithm changes to use the x\y from the environment variable\object, and you can reset that value as you wish, with another script that prompts the user for it. Resetting the defaults for this variable allows you to set this to zero or null, and that way you don’t accidentally use old values on a new layer\comp. This last part is, however, a lot of work for little payout.
