Activity Forums Adobe After Effects scaling images in a mask
  • scaling images in a mask
    Posted by Chris H on July 13, 2006 at 11:14 pm
    Hi-Simple question that I can’t figure out. I have a mask and I want to scale the image being masked, leaving the mask as is. How do I do this?
    choop
    Chris H replied 20 years, 1 month ago 4 Members · 5 Replies
  • Matt Wafaie
    July 13, 2006 at 11:40 pm
    do you mean the mask stays as it is by not scaling or the mask stays as it is in proportion to the image therefore scaling as well?
  • Michael Duff
    July 13, 2006 at 11:53 pm
    I’m not really sure of an answer, but I’ve got a couple possible work arounds.
    maybe you could pre-comp, and select “leave attributes” then scale everything up within the pre-comp?
    or instead of using a mask, make a track matte layer – then you can control both layers independently
    Michael Duff –
    Bearcage Productions, Australia
  • Stormdave
    July 14, 2006 at 3:37 am
    There are workarounds but there is no way to resize the image underlaying a mask. You can however change position…My suggestion would be to CUT the mask (CTRL+X or CMD+X on a Mac) and then resize your layer, and paste the mask on it. Make sure to make a backup of your layer just in case.
  • Stormdave
    July 14, 2006 at 3:46 am
    I skipped the part where you need to precomp your layer THEN paste the mask. Sorry for that, guys.
  • Chris H
    July 17, 2006 at 8:31 pm
    Thanks for the info everyone! Very helpful.
    choop
