Activity › Forums › Adobe After Effects Expressions › Scaling Drop Shadows when Collapse Transformations/Continuously Rasterise
  • Scaling Drop Shadows when Collapse Transformations/Continuously Rasterise
    Posted by Paul Ducco on February 13, 2023 at 10:23 pm
    I’m scratching my head again with assets that would ideally be contained in a single, reusable precomp…and running into problems with Drop Shadow (effect), when the placed precomp is scaled (and Collapse Transforms is on) the shadow settings remain as the original setting and don’t scale accordingly. Make sense?
    Thanks for any assistance in advance.
    Paul Ducco replied 3 years, 7 months ago 2 Members · 2 Replies
  • Andrei Popa
    February 14, 2023 at 5:57 pm
    The closest thing I can think of is essential graphics. Create essential graphics using the comp in which the drop shadow is as main comp. Add the drop shadow distance(and any other property that you want to modify). Where you use the comp as layer, select it and press “u” twice. On essential property distance, put an expression that also includes the scale. Smething like
    value * transform.scale[1] * 0.01
  • Paul Ducco
    February 15, 2023 at 10:40 pm
    Thanks for chiming in Andre. Did you resolve your issue?
    In our instance, it was easy enough to change how we accessed and applied the precomps, which meant, realistically (with the new approach) we can just apply the shadow to the placed precomp. Not going to work in every situation, but saved us a headache.
