Activity › Forums › Adobe After Effects › Scaling down large graphic-Stuttering playback
  • Scaling down large graphic-Stuttering playback
    Posted by Brent Garrett on December 29, 2012 at 5:25 pm
    Hello all,
    I have a project where my display is 1792×768. I am using Dataton’s Watchout to do an edge blend to create this resolution. The client would like to have a still graphic scale down over 3 minutes during the performance. It is a slow scale down. So I created a graphic that is 4 times the size of my display. They are just squares that scale down. The graphic is 7168×3072 now and I was going to take it into After Effects and scale it down to 1792×768 over 3 minutes. I understand that a graphic with the size 7168×3072 is huge and when I export the movie it has a hard time playing back smooth at 1792×768. It seems like the video will stop occasionally then start back up. I was wondering if anyone had an idea on how to make this playback smooth.
    I have an iMac 10.7.5/3.4GHz/i7/8gig Ram
    Brent
    Darby Edelen replied 13 years, 9 months ago 5 Members · 6 Replies
  • Roland R. kahlenberg
    December 29, 2012 at 5:29 pm
    Is there a good reason why you’re not using Shape Layers for the squares?
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
  • Vishesh Arora
    December 29, 2012 at 5:32 pm
    Brent
    The information is incomplete.
    What codec you have used for rendering? Is it lossless or compressed?
    If it is Lossless, the playback will have some problem.
    Also, Using Scale Parameter creates Jerk if the values are too big because of the math used in scale.
    I would suggest you to make the comp 3D and then displace is in Z – axis to mimic the scale effect.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Vishesh Arora
    December 29, 2012 at 5:38 pm
    This may help:
    https://allbetsareoff.com/tutorials/fixing-scaling-issues-part-1/
    Vishesh Arora
    Films Rajendra
    Blog:
    Demo Reel(3D):
  • John Cuevas
    December 29, 2012 at 6:06 pm
    You may want to read this:
    FAQ: Why is my output file huge, and why doesn’t it play back smoothly in a media player?
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Brent Garrett
    December 29, 2012 at 6:16 pm
    I am using mpeg 2 to export my video. I could use any type of codec from qt to wmv but Watchout would prefer mpeg 2. Also I forgot to mention that the graphic is an illustrator file originally. I converted it to a rasterized file and was trying to use Premiere to scale the graphic originally. I have to make sure the squares start out being 2’x2’in size when projected then shrink down over time. So I made them 128 pixels x 128 pixels for my pixels per foot ratio to make them 2’x2′.
  • Darby Edelen
    December 30, 2012 at 2:18 am
    Is the issue during playback after render, during RAM preview in AE or both?
    Darby Edelen
