Activity Forums Adobe After Effects Scaling down in AE for 3d Set
  • Scaling down in AE for 3d Set
    Posted by Chris Powers on October 20, 2009 at 2:34 pm
    So, I am making a 3d set with a live action actor shot on GS composed in. Its not too complicated, but the set is a LARGE scale building that the camera pushes in toward. I’m hoping to push right up to the front door of the building that is VERY small compared to the overal scale. (I really want to hit that this is a massive building you wouldn’t find normally).
    The problem is, i’m hoping to have a live action actor waiting for us at that entrace (a 3d layer of a pre-shot actor with camera moves etc. to coordinate with the 3d space.)
    Here’s were I get confused. In order to make my Actor the right scale it needs to be at about 8 to 10% scale, and by that time it’s lost ALL sharpness and is just a ball of pixels.
    Can anyone think of a work around for this? Is there a way to scale footage down without loosing quality? Any little tricks you might be able to think of? (I tried a slow scale up as the camera zooms in, but that really throws off the look). Or is this just past AE’s limitations and I need to tweak my vision for this shot?
    Thanks for any help/suggestions!
    -Chris
    Chris Powers replied 16 years, 10 months ago 2 Members · 3 Replies
  • Tony Silva
    October 20, 2009 at 4:19 pm
    what are you using for your building? An image? stock footage?
    No, there isn’t a way to scale footage and not lose quality, I don’t care how much CSI you watch, it’s not possible.
    Sounds like you need multiple shots of the building where you can comp them together to get good enough resolution at the end. It’s the same technique as VideoCopilot’s Earth Zoom tutorial.
  • Chris Powers
    October 20, 2009 at 7:24 pm
    Ahh, all good questions!
    1) No, I really haven’t ever done anything like this. but, hopefully, if you ask me that question in a weeks time, my answer will be yes! What I want to create needs a CG set and since I don’t know any 3d programs, I’m hoping to build it in AE. The video will require 5 3d sets with camera moving through them tracking the actor.
    I’ve already built and tested 3 of them and it’s going pretty well. Sure its all VERY new, but I’ve got to forge ahead and do something totally new or else I’ll get pretty stale pretty quick.
    2)No, I only have an HDV camera sadly and there’s no budget to get anything more. I know, it won’t be hollywood quality, but the actors are pretty small on screen so I should be safe. (And I do have all the Chroma equiptment. I blew a bulb last week but should have that back soon)
    3) Yes, I’ve shot some test footage with myself as the actor and its worked pretty well so far.
    And, I think I’ve found a work around for the problem. The issue was my actor being fuzzy by the time the camera has moved up to them, well, I think I’ll just fade to the next shot before the audience can really notice the fuzz. Pluss, its all glowing and ethereal anyway, it should fit in with the other distortion…I hope.
    Plus, my test footage is SD, hopefully when I use HD it will increase the sharpness a bit.
    Thanks for your input guys!
  • Chris Powers
    October 21, 2009 at 2:15 pm
    My final comp will be SD so I was hoping HDV would end up looking ok. I’m not familiar with “convert[ing] it to a non-temporally-compressed codec” How exactly do I do that and what is it? Sounds like something I should do though.
    And thanks for the link, that is actually the first place I went when I knew I wanted to do something like this. There’s lots of good tips in there.
    Thanks for your help,
    -Chris
