Activity › Forums › Adobe Premiere Pro › Scaling copy bug
  • Scaling copy bug
    Posted by Oliver Peters on November 11, 2017 at 10:46 pm
    I frequently use oversized clips in my sequences, like 4K shots inside 1080 timelines. I normally use “set to frame size” when I edit, so a 4K clip has a 50% value. If I need to punch in, then the scale might change to 75% with a slight X/Y position offset. When I copy-and-paste clips between sequences, this type of sizing information is lost. Generally position information is retained, but the scale value is wrong. Are others seeing this bug? It’s been there for several CC versions. Any suggestions?
    – Oliver
    Oliver Peters – oliverpeters.com
    Herb Sevush replied 8 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • John Pale
    November 12, 2017 at 1:03 am
    Yes.’ The only solution is to turn off auto set to frame size
  • Oliver Peters
    November 12, 2017 at 1:21 am
    [John Pale] “Yes.’ The only solution is to turn off auto set to frame size”
    Do you mean when you make perform the paste function? I know you mean in general, but would it work if only off when you paste?
    – Oliver
  • Greg Janza
    November 12, 2017 at 3:10 am
    I have the same problem and it ‘s quite an annoyance. If the solution is to turn off auto set to frame size that’s great but where is that setting now in Premiere?
    I Hate Television. I Hate It As Much As Peanuts. But I Can’t Stop Eating Peanuts.
    – Orson Welles
  • John Pale
    November 12, 2017 at 6:52 pm
    Not in front of my system now, but I think it’s in Preferences/Media
  • John Pale
    November 12, 2017 at 6:58 pm
    If the setting is turned off, paste works correctly.
    If it is on, motion settings don’t get included in pastes.
  • Oliver Peters
    November 12, 2017 at 7:10 pm
    Thanks.
    – Oliver
  • Herb Sevush
    November 13, 2017 at 1:31 am
    [greg janza] “I have the same problem and it ‘s quite an annoyance.”
    Yes, a big time PITA.
    Herb Sevush
    Zebra Productions
    nothin\’ attached to nothin\’
    \”Deciding the spine is the process of editing\” F. Bieberkopf
