Activity Forums Adobe Premiere Pro Scaling changes causes flickering in seq
  • Scaling changes causes flickering in seq
    Posted by Joseph Harkins on November 12, 2014 at 4:40 pm
    Adobe PP CC. I’m working w someone else’s cut. To create a zoom effect theother editor keyframed the scaling on quite a few shots. For some reason when it is played in the time line it’s causing almost a rolling shutter look in the back ground of the shot. The rolling shutter look is always in a bush or tree in the back ground, and not on the main subject, but is very noticeable.
    I’m working on a late 2013 Mac Pro w/ up to date Creative cloud.
    This type of issue is on multiple projects. There is no distortion on the raw footage, or if the shot is placed in the seq w/out the scaling changes.
    Any help would be appreciated.
    Joseph Harkins replied 11 years, 9 months ago 3 Members · 4 Replies
  • David Hawksworth
    November 12, 2014 at 5:50 pm
    Hopefully I’m envisioning your issue correctly. If you haven’t already, try rendering and/or playing at full resolution.
    David Hawksworth
    Video Producer
    Eagle Communications, Inc.
    Abilene, KS
  • Joseph Harkins
    November 12, 2014 at 6:00 pm
    I have done both already.
    This is a project I need to lay to tape (client’s requirement). I thought maybe it was just showing up in the previews, but it is definitely noticeable on tape too.
  • Kevin Monahan
    November 12, 2014 at 7:54 pm
    Hi Joseph,
    What happens if you switch to Mercury Playback Engine Software Only?
    Do you have Warp Stabilizer applied? What happens if you remove it?
    Is scale keyframed in a nested sequence?
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Joseph Harkins
    November 12, 2014 at 9:20 pm
    Switched mercury playback w/ no luck.
    No warp stabilizer or nested seqs.
    I actually found a fix. In the seq right click to “Field options” select “deinterlace always.”
    So far that seems to do the trick.
