Activity › Forums › Adobe After Effects Expressions › Scaling according to Position
  • Scaling according to Position
    Posted by Sam Isfat on October 18, 2020 at 4:05 pm
    In the beginning, the image will be in the center box and its size will be Wf and I can drag it to left/right/up/down. Its size will change according to the logic of the image I attached. As this scaling will depend on the position I can’t figure out how to do it. How can I achieve my desired result?
    Sam Isfat replied 5 years, 11 months ago 2 Members · 5 Replies
  • Dan Ebberts
    October 18, 2020 at 4:56 pm
    I’m not sure it’s exactly right, but probably something like this:
    wm = 50;
    wf = 150;
    R = wf/Math.SQRT2;
    center = [thisComp.width,thisComp.height]/2;
    r = length(position,center)
    ws = linear(r,0,R,wf,wm);
    [ws,ws]
  • Sam Isfat
    October 19, 2020 at 6:22 am
    Thanks, it’s almost working but what if I don’t want the center value as the center of the composition. I want it something like [200,300] as I declare. Do you have any idea how to do that?
  • Sam Isfat
    October 19, 2020 at 6:26 am
    I tried it like “center = [100,300];” this. But then the whole code is not working.
  • Dan Ebberts
    October 19, 2020 at 7:04 am
    That works for me. In what way is it not working for you?
  • Sam Isfat
    October 19, 2020 at 11:30 am
    yeah,it worked..thank you so much
    This is how achived it:
    wm = 100;
    wf = 496;
    R = wf/Math.SQRT2;
    center = [540.7397,627];
    r = length(position,center);
    wa=wf+((r/R)*(wm-wf));
    ws = linear(r,0,R,wa,wm);
    [ws,ws]
