Activity Forums Adobe Illustrator Scale/rotate of specific points (direct selected)…
  • Scale/rotate of specific points (direct selected)…
    Posted by Christof Van niekerk on June 1, 2018 at 10:24 am
    Seems like the simplest thing to accomplish & I’m just not winning with it:
    I want to use direct selection and grab 2 or 3 points of my shape & then get a transformation box to scale, rotate, move ONLY those points … can’t for the love of me figure out how to do this.
    Will greatly appreciate help.
    Kalleheikki Kannisto replied 8 years, 2 months ago 3 Members · 5 Replies
  • Kalleheikki Kannisto
    June 2, 2018 at 12:38 pm
    I’m pretty sure Illustrator doesn’t give you a bounding box on selected points — at least I’ve never seen such — but you can obviously use the rotate, scale and other tools on the selected points as well as drag to move them.
    Senior Graphic Designer
  • Christof Van niekerk
    June 4, 2018 at 7:14 pm
    LOL… feel like such a fool… thanks so much for your help Kalleheikki Kannisto.
    Because I never actually use the tools (rotate, scale etc.) individually … (I always just select a shape & manipulate
    handles on the box, or only MOVE points when directly selected… I’ve never actually known about the tools ????
    Thanks a bunch!
    June 5, 2018 at 3:39 pm
    No problem. Sometimes it’s the simple things that get you 😀
  • Angie Taylor
    June 17, 2018 at 7:10 am
    To see a bounding box after selecting one or two points with the Direct Selection tool you can also use the Free Transform tool. First, select the points you wish to manipulate. Then select the Free Transform tool (Annoyingly hidden under the Puppet Warp tool!). This will place a bounding box around your selection, allowing you to move, Scale or rotate the selection.
    cheers,
    Angie Taylor | Creative Cabin Ltd | Linkedin Instructor | Adobe Community Professional
    https://www.creativecabin.co.uk
    https://www.lynda.com/Angie-Taylor/2131450-1.html
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
    June 18, 2018 at 7:25 pm
    Interesting. Well hidden that tool is. Unfortunately it doesn’t make a box around the selection, rather the entire object. But it does work — at least until you undo, at which point it selects the entire shape again.
