Activity Forums Adobe After Effects Scale without a filter?
  • Scale without a filter?
    Posted by Marc Brown on April 21, 2011 at 11:28 pm
    Basically I have a 176×223 video whose horizontal resolution I am trying to double. The nature of the video, plus the fact that it is a low resolution, means what I’m specifically attempting to do is double the horizontal pixels.
    It is no surprise that After Effects chooses to give a filtered result in order to smooth out the scaling operation. (So that therefore what starts out as nice, sharp, digital edges becomes softened and unusable.) But I was surprised at my inability to find a way to change how it handles scaling.
    It also didn’t help to drag the video to an oversized comp, scale it there, and drag it back to a 352×223 comp. Aside from the fact that I never got anything usable out of this idea, the problem is that the blurriness being applied to the pixels is doubled in the horizontal, so even if it had worked, it wouldn’t have worked.
    Probably a dumb question with a quick and easy answer. Thanks for any help.
    Walter Soyka replied 15 years, 5 months ago 3 Members · 3 Replies
  • Tudor “ted” jelescu
    April 21, 2011 at 11:42 pm
    The quick answer is: NO, you can’t do that without a filter.
    That being said you may try using a filter like this one to enlarge the size of your footage:
    https://www.redgiantsoftware.com/products/all/magic-bullet-instant-hd/
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Marc Brown
    April 22, 2011 at 12:28 am
    Solved my own problem.
    I felt like I was hitting a brick wall. Worse than that. The inability to do something so simple was manifestly inexplicable. Even Photoshop (my last result) failed, because its nearest-neighbor algorithm comes packaged with an undefeatable sharpening process that destroys the image.
    Thank bog for VirtualDub and its flexible built-in resize filter. Back to work.
  • Walter Soyka
    April 22, 2011 at 12:46 am
    It seems I’m a little too late, but in AE, turning the layer’s quality switch [link] from Best to Draft might give you the look you want. You’d have to be careful to render the layer at draft quality, though, as most render settings default all quality switches to high.
    Walter Soyka
