Activity › Forums › Adobe After Effects Expressions › Scale up to random value
  • Scale up to random value
    Posted by Assaf Tshuva on April 19, 2016 at 3:51 pm
    Hello,
    I have a very large stock of objects that I want each to scale from 0 up to a random size (something between 2-6 percent, for example), and stay there, instead of keyframing all of them.
    The animation length could be fixed for all (let’s say 1 sec), but each object should start at different time (I’ve seen some expressions that could make such animations but relied on the global time code).
    Thanks in advance.
    Assaf Tshuva replied 10 years, 5 months ago 2 Members · 2 Replies
  • Dan Ebberts
    April 19, 2016 at 4:38 pm
    Like this maybe:
    maxDelay = 2;
    rampTime = 1;
    minVal = 2;
    maxVal = 6;
    seedRandom(index,true);
    delay = random(maxDelay);
    val = random(minVal,maxVal);
    linear(time,inPoint+delay,inPoint+delay+rampTime,0,[val,val])
    Dan
  • Assaf Tshuva
    April 20, 2016 at 10:19 am
    Worked perfectly (took down the delay parts, though), thank you.
    I still don’t get the linear expression…
