Activity › Forums › Adobe Premiere Pro › Scale to Sequence size not working on Premiere Pro CS5
  • Scale to Sequence size not working on Premiere Pro CS5
    Posted by Dustin Bowser on May 28, 2010 at 1:39 am
    I’m editing some RED .R3D footage that is 4K, but I’m cutting it into a 1920×1080 sequence. I have the “Scale to Sequence Size” option checked in my preferences but for some reason it won’t do it. Whenever I edit a clip into the sequence, it just shows up as 4K, and I have to right click the clip specifically and choose “scale to sequence size”. Seems like a bug, unless there isn’t something I have set wrong.
    Also, another little glitch is the function “Go to next edit point” or “Go to previous edit point” isn’t working either.
    Sylvia Porter replied 16 years, 4 months ago 3 Members · 2 Replies
  • Mike Velte
    May 28, 2010 at 10:50 am
    Page up/down will go to the next edit point only in selected tracks.
  • Sylvia Porter
    May 29, 2010 at 12:20 pm
    Dustin,
    Here’s a silly little thing about that “scale to frame size” feature. All of the clips you import into your project (not timeline) after you select that get scaled. Any you import prior to that won’t get scaled automatically unless you remove them and re-import them.
    As a workaround, I suggest a keyboard shortcut of your choosing.
    The shortcut is in ‘clip’ > ‘video options’ under edit>keyboard customization. Obviously, select the clip and use your shortcut.
    The good news is you can select multiple clips and invoke the command.
    Previous edit point and next edit point work only on tracks that are selected…ie, highlighted on the left side of the timeline. I also have keyboard shortcuts set up for selecting my video tracks.
    Holding shift and selecting a track selects all tracks.
