Activity › Forums › Adobe Encore DVD › Scale to Fill exporting from encore 16:9 1440×1080 30fps for DVD
  • Scale to Fill exporting from encore 16:9 1440×1080 30fps for DVD
    Posted by Bec Mills on January 10, 2013 at 4:10 am
    Wanting to export out of encore to burn to DVD- needing some help with exact settings to prevent horizontal and vertical stretch and letter boxing from continuing.
    Currently using cs6 premiere pro for sequence and queueing through to encore for export. Have tried for two weeks and many many hours to knit it out.
    – for a PAL DVD do i need to select:
    a. scale to fill option
    b. keep pixel at1.0 or change to HD Anamorphic or other
    c. do both
    d. none of the above and ….try this:
    Thanks in advance!
    Bec Mills replied 13 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
