Scale text expression with maximum cap
Hello,
I’m working on a template and I’m stuck!
I need an expression that scales down a text layer when there’s too much text, so that it always stays inside the comp, so autoscaling. But… the layer should only scale down when it gets too big, not scale up when it is smaller than the original. So basically, never scale to less than 100%. I know about autoscaling expression but those also scale up the text. Does anyone know how to do this?
