Activity Forums Adobe InDesign Scale stroke &/or outline stroke
  • Scale stroke &/or outline stroke
    Posted by Tj Sochor on May 19, 2006 at 4:08 am
    Is there a way to scale the point size of the stroke when resizing like you can in Illustrator?
    or to transform a thick stroke to outlines?
    (ex: to turn a short line into a filled rectangle.)
    Alex Salerno replied 20 years, 4 months ago 2 Members · 1 Reply
  • Alex Salerno
    May 24, 2006 at 6:10 pm
    Weird! The only way I could get line weight to rescale was only if the line was part of a group and then to scale with the Direct Selection tool using the command key (adding Shift is optional). This did not work when scaling the line object alone or when using the Free Transform tool!! Let me know.
    Alex
