Activity Forums Adobe After Effects Expressions Scale Selected Layers Script
  • Scale Selected Layers Script
    Posted by Jon Smith on April 18, 2013 at 4:59 pm
    Hey All,
    After Effects comes with a script called “Scale Selected Layers”. It basically creates a null either in the center or upper left of the composition then parents the layers and scales it by a user inputed value. I’m looking for something that just scales the layers without parenting them to a null. I figured I could customize the script to do what I need but after trying a few things I can’t seem to pull it off. Could someone point me in the right direction. Thanks!
    Jon Smith replied 13 years, 5 months ago 1 Member · 1 Reply
  • Jon Smith
    April 18, 2013 at 9:44 pm
    I finally got it to work. If anyone is interested here’s the script. It’s a modified version of the “Scale Selected Layers” Script and is handy if you need to scale a bunch of layers by a certain percentage. You can just save the script out as a .jsx file and it should work.
    // Scale Selected Layers Individually.jsx
    // This is a modified script based on :
    // "Scale Selected Layers.jsx" that comes with After Effects
    // This script scales the selected layers within the active comp.
    // First, it prompts the user for a scale_factor.
    // Next, it scales all selected layers, individually
    function ScaleSelectedLayers(thisObj)
    var scriptName = "Scale Selected Layers";
    // This variable stores the scale_factor.
    var scale_factor = 1.0;
    // This function is called when the user enters text for the scale.
    function on_textInput_changed()
    // Set the scale_factor based on the text.
    var value = this.text;
    if (isNaN(value)) {
    alert(value + " is not a number. Please enter a number.", scriptName);
    } else {
    scale_factor = value;
    function onScaleClick()
    var activeItem = app.project.activeItem;
    if ((activeItem == null) || !(activeItem instanceof CompItem)) {
    alert("Please select or open a composition first.", scriptName);
    } else {
    var selectedLayers = activeItem.selectedLayers;
    if (activeItem.selectedLayers.length == 0) {
    alert("Please select at least one layer in the active comp first.", scriptName);
    } else {
    // Validate the input field, in case the user didn't defocus it first (which often can be the case).
    this.parent.parent.optsRow.text_input.notify("onChange");
    var activeComp = activeItem;
    // By bracketing the operations with begin/end undo group, we can
    // undo the whole script with one undo operation.
    app.beginUndoGroup(scriptName);
    // Scales the layers.
    var myLayers = activeItem.selectedLayers;
    for (i=0; i <= myLayers.length-1; i++){
    currentLayer = myLayers[i];
    var layerScale = currentLayer.scale.value;
    layerScale[0] = layerScale[0] * scale_factor;
    layerScale[1] = layerScale[1] * scale_factor;
    currentLayer.scale.setValue(layerScale);
    app.endUndoGroup();
    // Reset scale_factor to 1.0 for next use.
    scale_factor = 1.0;
    this.parent.parent.optsRow.text_input.text = "1.0";
    // This function puts up a modal dialog asking for a scale_factor.
    // Once the user enters a value, the dialog closes, and the script scales the comp.
    function BuildAndShowUI(thisObj)
    // Create and show a floating palette.
    var my_palette = (thisObj instanceof Panel) ? thisObj : new Window("palette", scriptName, undefined, {resizeable:true});
    if (my_palette != null)
    var res =
    "group {
    orientation:'column', alignment:['fill','top'], alignChildren:['left','top'], spacing:5, margins:[0,0,0,0],
    optsRow: Group {
    text_input: EditText { text:'1.0', alignment:['center','top'], preferredSize:[200,20] },
    cmds: Group {
    okButton: Button { text:'Scale', alignment:['fill','center'] },
    my_palette.margins = [10,10,10,10];
    my_palette.grp = my_palette.add(res);
    // Workaround to ensure the edittext text color is black, even at darker UI brightness levels.
    var winGfx = my_palette.graphics;
    var darkColorBrush = winGfx.newPen(winGfx.BrushType.SOLID_COLOR, [0,0,0], 1);
    my_palette.grp.optsRow.text_input.graphics.foregroundColor = darkColorBrush;
    // Set the callback. When the user enters text, this will be called.
    my_palette.grp.optsRow.text_input.onChange = on_textInput_changed;
    my_palette.grp.cmds.okButton.onClick = onScaleClick;
    my_palette.onResizing = my_palette.onResize = function () {this.layout.resize();}
    return my_palette;
    // The main script.
    if (parseFloat(app.version) < 8) {
    alert("This script requires After Effects CS3 or later.", scriptName);
    return;
    var my_palette = BuildAndShowUI(thisObj);
    if (my_palette != null) {
    if (my_palette instanceof Window) {
    my_palette.center();
    my_palette.show();
    } else {
    my_palette.layout.layout(true);
    my_palette.layout.resize();
    } else {
    alert("Could not open the user interface.", scriptName);
    ScaleSelectedLayers(this);
