Activity › Forums › Zaxwerks › scale question
  • scale question
    Posted by Lensflare1 on June 28, 2006 at 12:19 am
    Hi There.
    In Proanimator 4, I am making a 3D bar graph, where each bar (a cube) is set to zero and rises accordingly from base.
    When i animate the scale of the cube it scales in both directions from the center.
    How can I set an anchor point to be positioned at the base , so the scale allows the bar to “rise”?
    Lensflare
    Lensflare1 replied 20 years, 3 months ago 2 Members · 4 Replies
  • Jon Okerstrom
    June 28, 2006 at 4:34 am
    Hi Lensflare,
    I’m not certain there is a way, but can think of one work-around:
    Why not put a plane at 0,0,0 to represent the floor of your 3d graph. With the right size and camera angle, it’ll hide the scaling that’s happening in negative y space.
    Jon
  • Lensflare1
    June 28, 2006 at 10:56 am
    Cheers Jon.
    Will give it a go. Quite surprised there isa no anchor point adjustment…
    Lensflare
  • Jon Okerstrom
    June 28, 2006 at 12:49 pm
    Hi Lensflare,
    When you use PA as an AE plug-in, there is a way to adjust the anchor point… look under the transform twirlie in the AE timeline. While this adjusts the anchor point it does not appear to affect whether scaling works in both positive and negative directions. If I find another solution, I’ll post the answer here.
    Jon
  • Lensflare1
    June 29, 2006 at 4:23 am
    Nice. Thanks Jon
    “That Camel had it coming I tells ya….”
