Activity › Forums › Boris FX Particle Illusion › Scale Project Question
Posted by Miss Tapya on December 7, 2007 at 6:59 pmHello to all:
The new feature of PIllusion 3.0.2
scale projectcan anyone please help me
with any guidelines
what values I should
put if I want my
project to render in
a good resolution output
for video.I want to use my project for some
dvd menus but kept making it so
low resolution…I want it crisp and clear..thanks
Erik Gertscher replied 18 years, 8 months ago 3 Members · 7 Replies -
Alan Lorence
December 7, 2007 at 9:26 pmFor DVD you want to use 720 x 480 (I believe) and set this in the Project Settings dialog.
When saving output, if you really want to save an AVI, use a lossless codec like Huffy UV or Lagarith for perfect (lossless) quality. Or save as a TGA or PNG image sequence.
I believe what you’re describing is compression problems in the output, not the output resolution.
Alan.
Miss Tapya
December 8, 2007 at 4:00 amThank You Alan…
yes you are right….
compression problems in the output. -
Erik Gertscher
December 10, 2007 at 10:31 amI also have a question about the new feature, it looks to me that the emitters are not scaled to the new outzput size i choose. is there a way i can scale them automatically?
Alan Lorence
December 10, 2007 at 1:13 pmThey ARE scaled (otherwise what’s the point of this feature). If you have an example that appears not to work correctly, please send it to me IMMEDIATELY, as we’re about to release the 3.0.3 update.
support at wondertouch dot com
Alan.
Alan Lorence
December 14, 2007 at 1:43 pmYou have to scale up to 1920 x 1440 (or whatever), then use the Project Settings to decrease the height (crops off the top and bottom). Or scale up to ____ x 1080, then use Project Settings to increase the width to 1920 (adds to the sides).
Alan.
