Activity Forums Adobe After Effects Scale problem dragging quicktime from the project window to the timeline
  • Scale problem dragging quicktime from the project window to the timeline
    Posted by Peter Karacas on June 23, 2006 at 5:12 pm
    I’m having a scale problem when I’m dragging a quicktime movie to the timline from the project window…it says it’s 100% but it’s not filling up the composition window. Any ideas how to fix this? Thanks!
    Sanspoof replied 20 years, 1 month ago 2 Members · 1 Reply
  • Sanspoof
    June 24, 2006 at 2:42 am
    You can make any video file constrain itself to fit the entire comp window by making sure the video is selected in the timeline and hitting ctrl+alt+f. However, it will not keep the current aspect ratio (dimensions in relation to eachother) the same so your footage will most likely look skewed.
    If you want to make a video file larger but don’t want to lose it’s aspect ratio, scale up past 100% under the transform>scale twirldown menu. Just remember that whenever you scale up past 100% after effects is interpolating the extra information… i.e. a loss in quality from the original footage.
    peace,
    Michael
