Activity Forums Adobe After Effects Expressions scale linked to z positon
  • scale linked to z positon
    Posted by Aj Vonwolfe on April 10, 2014 at 8:32 pm
    I’d like to offset the scale of an item with the z position so that as I move the item in z space, the item stays the same size.
    AJ VonWolfe
    Media Creator
    Beverton, OR
    “Imagination is more important than knowledge.”
    -Albert Einstein
    James Peres replied 12 years, 5 months ago 2 Members · 1 Reply
  • James Peres
    April 11, 2014 at 2:08 am
    You can try multiplying your scale by (z + 1.0), so that at when z=0, scale is 100% of it’s value. When z=2, then 200% and so forth. You can then multiply it by a factor to make the scale up not as dramatic.
    James
    Mac Pro 4,1 Quad Core 2.66
