Activity Forums Adobe After Effects Expressions Scale Linked to X and Y sliders at the same time?
  • Scale Linked to X and Y sliders at the same time?
    Posted by Ian Thomson on October 16, 2008 at 9:16 pm
    temp=effect("Separate XYZ Position") ("X Position")+100;
    if(temp<0) temp *= -1;
    [temp,temp,temp]
    Hello again!
    I got some excellent help for linking a layer Scale property to a slider and keeping the results positive, https://forums.creativecow.net/readpost/227/11350
    Now my more complicated question is this; is it possible to link scale to separate sliders (X position) and (Y position) and both have them affect the scale equally?
    Basically what we’re trying to do is Pan footage (X/Y) and have it automatically scale/crop to fit the comp. Some clips require panning X, some Y, Some both.
    Is it possible to link scale to 2 different values? Or is there a better way to go about this sort of thing?
    Any help here Highly appreciated!!!
    -Ian
    Brendan Mccullough replied 17 years, 10 months ago 2 Members · 1 Reply
  • Brendan Mccullough
    October 16, 2008 at 11:44 pm
    x=effect("Separate XYZ Position") ("X Position")+100;
    y=effect("Separate XYZ Position") ("Y Position")+100;
    if(x<0) x *= -1;
    if(y<0) y *= -1;
    if(x>y) [x,x];
    else [y,y];
    You can’t have it link to two values at the same time, but what if it was selective? This example only uses the greater of the two values…
