Activity › Forums › Adobe After Effects › Scale Layer to fit composition using Script
  • Scale Layer to fit composition using Script
    Posted by Victor Pontes on December 27, 2012 at 1:22 pm
    Hello, i was looking for a script that could scale a layer to fit exactly the Compositon like a batch process. didn’t find any that work like this so far, any one here knows?
    Darby Edelen replied 13 years, 9 months ago 3 Members · 2 Replies
  • Stefan Hinze
    December 27, 2012 at 1:50 pm
    the first thing on my mind was: Use FT-Toolbar from aescripts.com and make this command part of the toolbar.
    (there are video-tutorials of the toolbar.. check them out!)
    (the toolbar is not for free, you need to buy a licens, but you can try it out for free, i bet you will buy it!)
    (take a step back, to see the bigger picture)
  • Darby Edelen
    December 28, 2012 at 4:04 am
    This may not be the answer you’re looking for but you can use the Layer > Transform > Fit To Comp menu option to fit a layer (or several layers) exactly to the size of the composition. The shortcut is cmd-opt-f on mac and ctrl-alt-f on windows.
    If you need to do this to specific layers in different compositions then I’m not sure if a script will be able to help you there.
    Darby Edelen
