Activity Forums Adobe After Effects Expressions Scale in/out – Frames
  • Scale in/out – Frames
    Posted by Alexander Weil on November 11, 2014 at 11:38 am
    Hello Creative Cows,
    I want to write an expression where my layer scales in and out at the start and end of my Layer Duration just like the “Fade In+Out – frames” from the After Effects Preset Behaviors. So i tooked the expression from the Preset and tried my best. it works but only for in or for the out fade. I know i need to add a last line of code to make them both work. maybe you can give me a hint or the solution
    thanks
    -alex
    fadeInDuration = thisComp.frameDuration *effect("Fade In+Out - frames")("Fade In Duration (frames)");
    fadeOutDuration = thisComp.frameDuration * effect("Fade In+Out - frames")("Fade Out Duration (frames)");
    startScale = [0,100];
    endScale = [15,100];
    fadeInScale = ease(time, inPoint, inPoint+fadeInDuration+0.001, startScale, endScale);
    fadeOutScale = ease(time, outPoint-fadeOutDuration-0.001, outPoint, endScale, startScale);
    Alexander Weil replied 11 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 11, 2014 at 4:56 pm
    Try replacing the last two lines with this:
    if (time < (inPoint+outPoint)/2)
    else
    Dan
  • Alexander Weil
    November 18, 2014 at 9:03 am
    Thanks Dan,
    that saved me a lot of time 🙂
    greetings from germany
    -alex
