Activity Forums Adobe After Effects Expressions Scale in relation to position in comp
  • Scale in relation to position in comp
    Posted by Chris Gosling on May 27, 2014 at 11:51 am
    I have found the following expression that adjusts the scale of a layer based on it’s x-position in a comp
    But what I need to do is base it’s x-position of a parent comp.
    Example:
    I have a comp containing a static timeline with icons. As the comp moves along the x-axis in a parent comp then the icons need to scale up and then down as they approach and pass the centre of the parent comp.
    I am pretty sure that I need to change the layer positioning space somehow but I am really confused in that regard.
    Any help would be appreciated.
    Chris
    offset = 100; //amount to scale up
    min = 0; //distance in pixels from the center where the layer is at full scale
    max = 300; //distance in pixels from the center where the layer is at 'normal' scale
    c = [thisComp.width / 2, thisComp.height / 2]; //center of the composition
    p = toComp(anchorPoint); //location of the current layer in the composition
    d = Math.abs((p - c)[0]); //distance from the center along the x-axis
    x = ease(d, min, max, offset, 0);
    value + [x,x,0]
    Dan Ebberts replied 7 years, 6 months ago 3 Members · 4 Replies
  • Dan Ebberts
    May 27, 2014 at 4:51 pm
    Try this (change the name of the parent comp to match yours):
    offset = 100;
    min = 0
    max = 300;
    C = comp(“Parent Comp”);
    L = C.layer(thisComp.name);
    center = [C.width, C.height]/2;
    p = L.toComp(toComp(anchorPoint));
    d = Math.abs((p – center)[0]);
    value + [x,x,0]
    Dan
  • Chris Gosling
    May 27, 2014 at 4:56 pm
    Thanx a million Dan – just the trick. Know I just have try and understand it 😉
    C
  • Alexandre Maye
    February 5, 2019 at 10:39 am
    Hi there,
    Great expression ! thanks a lot !
    How can I apply this method but not to the scale but to the opacity ?
    Thanks a lot ! 🙂
  • Dan Ebberts
    February 5, 2019 at 6:24 pm
    Try changing the last line to:
    value + x
    or maybe just:
    x
    (depending on how you want the opacity to respond)
    Dan
