Activity Forums Adobe After Effects Expressions Scale in + out based on layer length
  • Scale in + out based on layer length
    Posted by John Burgess on May 2, 2020 at 7:18 pm
    I found the below expression for scaling a layer in and out based on its length which works well.
    The issue is I was hoping to save it as a preset and this relies on the layer name being referenced which doesn’t make it the most efficient when applying it to multiple layers at the same time.
    Is there a way of simplifying this to allow it to be reusable or a better method?
    John
    startScale = [0,0];
    endScale = [100,100];
    layername = "Shape Layer 1";
    if(time < (thisComp.layer(layername).inPoint+thisComp.layer(layername).outPoint)/2)
    ease(time,thisComp.layer(layername).inPoint,thisComp.layer(layername).inPoint+0.2,startScale,endScale)
    else
    ease(time,thisComp.layer(layername).outPoint-0.2,thisComp.layer(layername).outPoint,endScale,startScale);
    UPDATE, SOLVED
    Worked out solution by using index if anyone is interested
    startScale = [0,0];
    if(time < (thisComp.layer(index).inPoint+thisComp.layer(index).outPoint)/2) ease(time,thisComp.layer(index).inPoint,thisComp.layer(index).inPoint+0.2,startScale,endScale) else ease(time,thisComp.layer(index).outPoint-0.2,thisComp.layer(index).outPoint,endScale,startScale);
    John Burgess replied 6 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 2, 2020 at 9:39 pm
    Actually, you can leave all that layer name/index stuff out:
    startScale = [0,0];
    if(time < (inPoint+outPoint)/2)
    ease(time,inPoint,inPoint+0.2,startScale,endScale)
    else
    ease(time,outPoint-0.2,outPoint,endScale,startScale);
    Dan
  • John Burgess
    May 2, 2020 at 9:46 pm
    Great, even better.
    Thanks very much Dan.
