Activity Forums Adobe After Effects Expressions Scale Expression with inertia bounce – start from zero
  • Scale Expression with inertia bounce – start from zero
    Posted by Justin Alexander on October 21, 2011 at 7:42 am
    Hi everyone,
    I have been using these forums for a long while and found them to be immeasurably helpful.
    What I am trying to do now is get a layer to scale in and scale out at its in and out points, along with a bit of an inertia spring.
    I have used one of Dan Ebberts scripts from one of the posts here and modified it a bit to work at in and out points.
    The problem I am having is that the layer needs to be constantly re-sized to get somewhat reasonable results. Most of the time it bounces out OK although it never seems to really get to 0% scale. The in point is the one that doesn’t work properly though. Rarely can I get it to start at 0% scale. I have to have the layer scaled to the right size and tweak the ‘Scale’ setting in the expression. I normally have the variable set to sliders but have replaced them with my default settings here for easier dissecting.
    I have the following script on a solid scaled at 40% in a 1050 x 576 comp. Solid was made comp size as I want this to work at any scale.
    What I want to accomplish is to have the layer start at 0& scale and ramp up to whatever I set before applying the script. Then have a bit of inertia bounce that can be adjusted for intensity and length. At the minute the inertia bounce is working beautifully, I just need the scale to start and finish a 0%.
    Then I want to be able to save it as a preset and have it save me hours of time over the next couple of years.
    Really hope that I have made sense and that someone is able to tell me where I have gone wrong.
    Regards
    Justin Alexander
    PS: Thanks to Roland R. Kahlenberg for pointing me to the correct forum for this issue
    S =100; // Scale
    A =20; // Amplitude
    F =20; // Fequency
    to = outPoint - time;
    ti = time - inPoint;
    inTrans = x=S*(1-Math.exp(-A*ti)*Math.cos(F*ti));
    outTrans = y=S*(1-Math.exp(-A*to)*Math.cos(F*to));
    value+ [inTrans,inTrans] + [outTrans,outTrans];
    Scott Green replied 11 years, 9 months ago 5 Members · 8 Replies
  • 8 Replies
  • Dan Ebberts
    October 21, 2011 at 4:31 pm
    I’m not sure this is what you’re describing, but give it a try and see if it’s close:
    rate = 500;
    rampDur = value[0]/rate;
    freq = 3;
    decay = 5;
    w = freq*Math.PI*2;
    if (time < (inPoint+outPoint)/2){
    if (time < (inPoint + rampDur)){
    s = linear(time,inPoint,inPoint+rampDur,0,value[0]);
    }else{
    t = time - (inPoint+rampDur);
    s = value[0] + rate*Math.sin(t*w)/Math.exp(t*decay)/w;
    }else{
    if (time > (outPoint - rampDur)){
    s = linear(time,outPoint-rampDur,outPoint,value[0],0);
    }else{
    t = (outPoint - rampDur) - time;
    [s,s]
    Dan
  • Justin Alexander
    October 21, 2011 at 9:19 pm
    Hi Dan,
    Thank you so much for solving my problem.
    That is absolutely what I was after.
    This will save me a heap of time over the next few yeas.
    Much appreciated
    Justin
  • Geoffrey Amend
    February 19, 2013 at 5:15 pm
    Hi. I’m researching how to get a star shape and a possibly a text layer (not sure if I’m going to have them connected or not) to “pop” up, hold for a second, so we can read the text and then pop back down to start position.
    I like this bounce action. Thank you for the expression.
    I put it on the P layer of the contents transform section…Should I put it on the P section of the Poystar path instead?
    Either way. I’m wondering how to control the start/stop points and also to get the shape to bounce back to position after holding….
    Any further assistance is greatly appreciated. Thank you very much.
    rate = 500;
    freq = 3;
    decay = 5;
    w = freq*Math.PI*2;
    if (time &lt; (inPoint+outPoint)/2){
    if (time &lt; (inPoint + rampDur)){
    }else{
    }else{
    }else{
    [s,s]
    Thank you!
  • Geoffrey Amend
    February 19, 2013 at 6:16 pm
    Figured it out with another expression I found. But would like to remove the bounce effect from the return movement and retain the initial movement bounce.
    n = 0;
    if (numKeys > 0){
    n = nearestKey(time).index;
    if (key(n).time > time){
    n--;
    if (n == 0){
    t = 0;
    }else{
    t = time - key(n).time;
    if (n > 0){
    v = velocityAtTime(key(n).time - thisComp.frameDuration/10);
    amp = .05;
    freq = 4.0;
    decay = 2.0;
    value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
    }else{
    value;
    Thank you!
  • Shane Mccleery
    July 31, 2013 at 7:22 pm
    Dan,
    This exp looks and works great.
    I’m just getting into AE and expressions and I was wondering what the proper steps to being able to use this script in reverse, or just be able to use this script going from any two sizes.
    Like say I want to go from 100% to 20% and still retain the intertial bounce how would I edit your script.
    I guess I just am not very good with changing variable and figuring out what they do.
  • Dan Ebberts
    July 31, 2013 at 7:35 pm
    I think I would use the keyframe version of the expression for that (set linear keyframes for 100% and 20% the apply this expression to the scale property) :
    freq = 3;
    decay = 5;
    n = 0;
    if (numKeys > 0){
    if (key(n).time > time) n--;
    if (n > 0){
    amp = velocityAtTime(key(n).time - .001);
    w = freq*Math.PI*2;
    value + amp*(Math.sin(t*w)/Math.exp(decay*t)/w);
    }else
    value
    More info here:
    https://www.motionscript.com/articles/bounce-and-overshoot.html#kf-overshoot
    Dan
  • Shane Mccleery
    July 31, 2013 at 8:04 pm
    Dan
    You are a good man!This is exactly what I was looking for. Thanks for all the help you provide to people like me and everyone in general 🙂
  • Scott Green
    December 23, 2014 at 4:32 pm
    I’ve been a big fan of this expression for some time now I’m just wondering if there’s a way that something can be added to it to make it scale back down to 0 after a set amount of time?
    I’ve only been able to achieve this by attaching my objects to a null and then scaling the null down where I want the object to scale out. Any ideas?
    Creative motion graphics, animation, video production and graphic design
