Activity Forums Adobe After Effects Expressions Scale Expression with Bounce Inertia
  • Scale Expression with Bounce Inertia
    Posted by Scott Skaja on November 9, 2016 at 1:50 pm
    I am ever learning at Expressions and am in need of help from people smarter than I.
    I want to scale an object and have it bounce to a stop. I found Dan Ebberts post on this topic from a few years ago. The expression listed below mostly works for me, the only thing I would like to eliminate is the bounce out, I just want it to scale bounce in and hold, that’s it. How would I modify the following to achieve this?
    rate = 500;
    rampDur = value[0]/rate;
    freq = 3;
    decay = 5;
    w = freq*Math.PI*2;
    if (time < (inPoint+outPoint)/2){
    if (time < (inPoint + rampDur)){
    s = linear(time,inPoint,inPoint+rampDur,0,value[0]);
    }else{
    t = time - (inPoint+rampDur);
    s = value[0] + rate*Math.sin(t*w)/Math.exp(t*decay)/w;
    }else{
    if (time > (outPoint - rampDur)){
    s = linear(time,outPoint-rampDur,outPoint,value[0],0);
    }else{
    t = (outPoint - rampDur) - time;
    [s,s]
    scott skaja
    tangletown post – edit•animate•design•composite•color correct
    tangletownpost.com
    Scott Skaja replied 9 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
