Activity Forums Adobe After Effects Scale expression
  • Scale expression
    Posted by Chris Holland on September 10, 2019 at 4:17 pm
    I need to create a map using dots, I want the dots to scale from 0-100 randomly over the space of 3 seconds to reveal/build the map.
    I came across a post on here where someone had the exact same problem and the answer was this expression. He used it for opacity so I’m hoping it will work for scale?
    I should also mention that I tried this expression on the opacity but I got an error message.
    Do I have to change any of the elements within this expression for it to work? Is some of the text placeholder for someone to put in certain dimensions? I’m a novice with expressions so I apologise for my lack of knowledge!
    maxTime = 3; // max time for all dots to appear
    seedRandom(index,true);
    myTime = random(maxTime);
    if (time > myTime) 100 else 0
    Thanks, I really hope you can help.
    Dan Ebberts replied 7 years ago 2 Members · 1 Reply
  • Dan Ebberts
    September 10, 2019 at 4:46 pm
    Try this:
    rampTime = .1;
    myTime = random(maxTime-rampTime);
    s = linear(time,myTime,myTime+rampTime,0,100);
    [s,s]
    Dan
