scale diff size media to a constant value
Howdy,
Just curious if someone, (Dan) can point me to a solution for scaling footage to a fixed size.
I have 6k, 4k, HD, footage… My current script scales footage to 25% of it original.
.property (“Scale”).setValue([25,25]);The problem here is this is a ratio rather than a fixed size.
So the result of the Poster image varies. 25% of the original.Can you suggest a way to set the resolution to a fixed Resolution. Something like 720×407. The constant is the aspect ratio, as it will always be 1.1:78 16×9.
So any size footage (assuming 1:78) will scale to a fixed 720×407.
Thanks for you help! Hope I explained that OK?
