Activity Forums Adobe After Effects scale and position issue copy pasted paths from AI or PS
  • scale and position issue copy pasted paths from AI or PS
    Posted by Simon Robbrecht on March 1, 2007 at 9:18 am
    When copying paths from Illustrator or Photoshop and pasting them onto an AE layer with the same dimensions, the paths have shrunk and have lost their original position.
    How can i copy-paste paths into After Effects (6.5) without losing their original dimensions and position?
    I’ve seen Aharon Rabinowitz’ tutorial on copying paths to AE and I followed his guidelines exactly, so there must be a setting or preference which I have to tweak.
    Thanks for your help!
    simon
    Simon Robbrecht replied 19 years, 6 months ago 2 Members · 3 Replies
  • Mylenium
    March 1, 2007 at 4:53 pm
    No, I don’t think that’s the full truth. It explains the shrinkage, but not the positional changes. The point here is, that as long as you only copy&paste a single path, AE will re-center it on the layer you paste to. Only multiple masks/ paths retain their relative positions.
    Mylenium
    [Pour Myl
  • Simon Robbrecht
    March 1, 2007 at 7:41 pm
    the fact is, I didn’t import a file; I only copy pasted the paths from a Photoshop document with the same dimensions as the AE comp and layers.
    I vaguely remember that there is a maximum number of masks per layer that AE can handle (how many?). Perhaps that’s where the problem comes from because i’m importing a few hundred paths (i’m only wildly guessing here).
  • Simon Robbrecht
    March 2, 2007 at 2:25 pm
    Both the AE composition and the .psd are set to square-pixels…
