Activity Forums Adobe After Effects Scale After Effects project
  • Scale After Effects project
    Posted by Dean Chapman on August 14, 2012 at 3:47 am
    Let’s say I have a project exported from C4D into AE at a size of 720×405.
    I do some rough compositing (masking, using some particles, adding typography) at this size, to show the client.
    The client gives me the go ahead, and I re-output the exact same 3D scene from C4D into AE, at a new size of 1920×1080 (same ratio).
    Is there a way to simply “up-rez” or scale my AE scene to fit the newly resized C4D project? Will my mask’s edges be off/softer? Will comps within comps, and cameras be offset? Will my particles be screwed up?
    Or do I simply have to rebuild my AE work from scratch at this new size?
    Dean
    Dean Chapman replied 14 years, 1 month ago 3 Members · 3 Replies
  • Dan Fredley
    August 14, 2012 at 3:59 am
    File>Scripts>Scale Composition.jsx will get you to a certain point. But you might have to tweak a few things manually.
  • Erik Lindahl
    August 14, 2012 at 10:37 am
    A good tip when wanting to work low res for a later high res out put is working on “perfect downscale” of the full-res. For 1920×1080 HD that would mean 960×540, 640×360 or 480×270. That makes it much easier up-resing.
    But try the above suggestion and see where that takes you!
  • Dean Chapman
    August 14, 2012 at 10:28 pm
    Very cool, thanks Dan.
    -d
