Activity › Forums › Adobe After Effects › Scale a rounded rectangle in a non uniform way without edge deformation
  • Scale a rounded rectangle in a non uniform way without edge deformation
    Posted by James Brockett on June 4, 2018 at 4:03 pm
    Has anyone had success scaling a rounded rectangle? I am attempting to scale a rounded rectangle from a widescreen shape to a portrait phone screen shape (not a uniform scale) and whenever I scale the rectangle in this fashion my rounded edges become notably off and deformed. I have tried changing the roundness with the rectangle and also using a mask shape and transforming the path instead of the shape with the same results.
    James Brockett replied 8 years, 3 months ago 3 Members · 3 Replies
  • Kevin Camp
    June 4, 2018 at 6:45 pm
    it depends on how the rounded rectangle was made.
    If it is a rasterized layer (like a png) then you won’t be able to do it.
    if it was made as a mask on a layer, then you won’t be able to use the scale property, but you could select point and move them manually.
    if it was made as a shape layer, then you’ll want to use the size property (contents>rectangle #>rectangle path #> size) to change the width or height while maintaining the roundness of the corners.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Kalleheikki Kannisto
    June 4, 2018 at 6:47 pm
    To retain correct corner rounding, the rectangle shouldn’t be scaled, rather you should adjust the width and height parameters.
    Senior Graphic Designer
  • James Brockett
    June 4, 2018 at 7:03 pm
    Thank you so much that was it! I never usually had problems scaling my shape layers until now, I forgot there was even another way to transform the shape that wouldn’t destroy the edges.
