Activity Forums Avid Media Composer SC icon/Color Adapter…How to work with this?
  • SC icon/Color Adapter…How to work with this?
    Posted by Dan Brother on May 25, 2016 at 6:11 pm
    Hello All.
    Editing on a MC V8.5. Working with 4K footage that was shot in SLog3 mode. (2 different cameras…a Sony F55 and an FS7)
    After bringing the footage in, it has an icon atop it in the timeline that says “SC”. When I move into effects mode, the effect editor calls it “Color Adapter”. But it doesn’t allow me to adjust it in any way. In fact, no parameters show up at all. This makes me think it is plug in that I do not have. Also I cannot remove it.
    I believe it is causing a problem where it wants to color correct the S Log 3 image on it’s own because when I apply a LUT, it’s causing about 80% of the footage to be blown out to the point where half the image is not even viewable, let alone using a critical eye on it.
    Can anyone explain what this is? And how it helps? I’m confused by this because I’ve never seen it pop up before.
    Thanks in advance!
    Dan
    Dan Brother replied 10 years, 3 months ago 2 Members · 2 Replies
  • Michael Phillips
    May 25, 2016 at 6:26 pm
    Depending on your color management settings, a LUT may already be applied automatically. This is done via right click on clip or clips and choose “source settings”. In there you will have 3 or more tabs depending on source file type. The color tab allows you to define source color space, add, remove, or bypass a LUT or change the order of operations of multiple LUTs are ASC CDL is applied.
    Michael
  • Dan Brother
    May 25, 2016 at 7:11 pm
    Thank you very much for your quick response, Michael! It was exactly what I needed.
    Dan
