Activity › Forums › Apple Final Cut Pro Legacy › Say it isn’t so
  • Say it isn’t so
    Posted by Eric Klassen on August 17, 2005 at 10:35 pm
    I’ve been able to get my PAL clips to play and compress in a NTSC timeline and DVDSP3 has accepted it. No it isn’t Nattress’ed but I have to get something out by tomorrow so I have to do it this way. I have over 100 markers on the PAL timeline I planned on carrying over as chapters into DVDSP3, but I can’t figure out how to copy them into the NTSC timeline. Is there any way to do this. I’m dreading that there is not. The markers don’t have to be frame by frame perfect, in fact, they could even be a second or two off and it would still be fine.
    e
    Rich Rubasch replied 21 years, 1 month ago 2 Members · 1 Reply
  • Rich Rubasch
    August 18, 2005 at 1:36 am
    Try duplicating the sequence, then changing the Sequence setting, rather than copy the clips. Or if you control click and see if there is a “copy markers” in there. But duplicating the sequence should leave them there, then just change the setting to Pal.
    Rich Rubasch
    Tilt Media
